Add a Multilink or LACP Trunk
Perform this procedure to add a multilink or LACP trunk.
Important
Ensure that all ports that belong to the same MLT/LACP group use the same port speed, for example, 1 Gbit/s, even if autonegotiation is used. This requirement is not enforced by the software.
When you add a VLAN to a dynamic MLT, only the active ports of the MLT are added as port members of the VLAN. Ports configured with the same aggregation key, but not active, are not added to the VLAN. If these inactive ports become active later, the system does not automatically add them to the VLAN port member list.
You must add all inactive ports to the VLAN. If you do not add the inactive ports to the VLAN, when they become active later, hashing can result in choosing a newly active port for traffic forwarding. Because the port is not a port member of the VLAN, traffic will be dropped. When you add the VLAN to the MLT, also add the inactive aggregation ports to the VLAN. You may have to disable LACP on the inactive ports before you can add them to the VLAN. Because the ports are inactive, disabling LACP does not cause a traffic interruption.
Similarly when you remove a VLAN from a dynamic MLT, all active ports of the MLT are removed from the VLAN port member list but the inactive members are not removed. You must remove the inactive aggregation members from the VLAN.
If you later configure a port for the same aggregation, you must add this port to all VLANs that are members of the MLT.
- Select MLT/LACP.
- Select the MultiLink/LACP Trunks tab.
- Select Insert.
- In Id, type the ID number of the MLT.
- In PortType, select access or trunk.
- Optional: In Name, type a name for the MLT, or accept the default.
- In PortMembers, select the ellipsis (...).
- In Port Editor: PortMembers, select the desired ports.
- Select Ok
- In VlanIdList, select the ellipsis (...),
- In VlanIdList, select the desired VLANs.
- Select Ok.
- In MltType, select the MLT type.
- Optional: In Aggregatable, select enable or disable.
- Optional: In PrivateVlanType, select trunk, isolated, or promiscuous.
- Select Insert.
MultiLink/LACP Trunks Field Descriptions
Use the data in the following table to use the MultiLink/LACP Trunks tab
Name |
Description |
Id |
Specifies a unique value for this MLT. |
PortType |
Specifies the value to access or trunk port. If the aggregatable field is set to enable, this field is read-only. The default value is access. |
Name |
Configures the name given to the MLT. |
PortMembers |
Assigns ports to the MLT. All ports in an MLT must have the same settings for speed and duplex, but can have different media types. All untagged ports must belong to the same STG. Up to eight same-type ports can belong to a single MLT. If the aggregatable field is set to enable, this field becomes read-only. Important:
Ensure that all ports that belong to the same MLT/LACP group use the same port speed, for example, 1 Gbps, even if autonegotiation is enabled. |
VlanIdList |
Indicates to which ports the VLANs belong. If the aggregation field is set to enable, this field is read-only. |
MltType |
Specifies the type of MLT
RunningType |
Specifies the MLT running type. |
IfIndex |
Specifies the interface of the trunk. |
ClearLinkAggregate |
Clears the link aggregate, disabling and reenabling the trunk. |
DesignatedPort |
Specifies the designated port of this trunk. |
Aggregatable |
Enables or disables link aggregation. The default value is disable. |
AggOperState |
Specifies the aggregation state of the trunk. |
AggTimeOfLastOperChange |
Specifies the time value since the interface entered its current operational state. |
PeerPortMembersList |
Specifies the peer ports connected to the local ports of this trunk. |
EntryOwner |
Defines the owner of the MLT. |
DatapathProgrammingState |
Defines the datapath programming state of the MLT. |
PrivateVlanType |
Specifies the type of private VLAN for the MLT. |
FlexUniEnable |
Specifies whether the Flex UNI is enabled or disabled on the port. The default value is disable. |
NodeAliasClear |
Specifies whether the Node Alias is enabled or disabled for the MLT. |
